Found a cure for my canopy frame blues!!
Getting the frame to match the roll bar was not that hard but once I got it right the aft end was too wide. I fought and fought with this until I was ready to pull my hair out. I finally came up with a plan that made it easy to adjust both the height and width of the bow! I used ratcheting straps to incrementally tune the aft bends in a controlled manner click by click. To measure results just loosen things up. Be patient, don't try to do it all at once. The wooden bar acting as a spacer between the front bow is critical. Worked like a charm. Hope this helps someone else.
PS: Does anyone have a bullet proof way to drill the deldrin blocks for the rear pins on the slider frame?
