TCONROY
I'm working on the canopy frame and have a question to ask fellow -7 builders. I've drilled and riveted the splice plate to the forward frame, but have NOT drilled the 1/4 holes for the hinge pins (release mechanism). I can't seem to get the skin to both have a 0.020" gap around the front AND for the left and right sides to sit perfectly above the fuselage side rails. If I shim for the 0.020 gap between the forward skin and canopy skin, the sides are at a little bit of an angle with probably a 0.5" gap, sitting above the fuselage side rails. If I set the sides correctly, I have a 0.05+ gap at the top portion between the two skins. It seems I can't achieve both. At one point I thought I had this right but it seems to have gotten off. Any suggestions?
http://rv7.conroyair.com/logindex/Finishing/2012.06.06.htm
