I searched the form and found several threads on the pros and cons of vertical verses horizontal induction
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I am not interested in that debate on this thread. What I am looking for is:
1. Opinions on ease of installation of the horizontal (snorkel).
See my comments below.
2. Longevity and repairs of that system.
I have approximately 180 hours now on my installation. I have had ZERO problems with anything even remotely related to my installation.
3. Opinions of ease of installation between vertical and horizontal
I have no experience with the vertical installation. My installation was very straight forward. See my comments below.
4. A thread that shows or directs help with the install of the horizontal induction
This is specific to ECi's installation (
which is what I used for my engine):
http://www.eci.aero/exp/RV6,7,9.pdf. If you have not consider ECi I suggest you look into their design.
5. Is the Vettermans exhaust without the muffler loud in the cabin
I have Vetterman's straight 4 pipe exhaust on my ECi IO-340 with forward facing cold air induction. I was not at all interested in a loud airplane when I was building. I was very reluctant to go with the straight pipes. I had visions of some loud hot rod with straight pipes barreling down the street with a raucous roar. Absolutely not even close to what my airplane sounds like. Is it loud in the cockpit without a headset? Well, yes. The RV cockpit is a very noisy environment with all of that metal banging around. Different than any other RV? I don't think so. Louder than a muffled RV? Maybe. Would I do it again? In a heartbeat!
The truth is, I have come to realize it is not really that loud. In the beginning I was always concerned with the noise my airplane was producing around the airport so I was constantly asking those who were around when I landed "How loud was my airplane?" "Was it as loud as that one over there when it came in?" Everyone who answered would tell me they did not think it was all that loud. I think it has that distinctive
RV sound. It does sound sweet!
6. Is additional heat transferred into the cabin due to this system verses vertical
I do not notice any heat transfer. But then again, I have a full interior from Classic Aero that includes an insulated carpet on the floor. I also have ceramic firewall insulation on the engine side of the firewall that is helping.
I just finished fighting with the snorkel/baffle installation. My installation was not easy at all, at least not to me. The common wisdom seems to be to cut the snorkel in half and glass it back together once you've got the two ends to fit on the servo and inlet ramp respectively.
Concerning questions 1 & 3 from above and John's comments, I had a very different experience installing my cold air induction. My installation was very painless. Now in order for that to be the case I did a lot of pre-purchase research and had multiple discussions with both ECi and Vans concerning what I would need. One of the most important things from Vans was to make sure to order the cowling and snorkel for the IO-360. This cowling is wider than the stock cowling and it does not have the snout. Because of this pre-planning, when it came for installation everything almost fit like a glove. I did not need to alter the Van's supplied snorkel in any way. ECi supplies a kit that mates the sump up to the Van's snorkel. It worked great! John mentioned having to alter the snorkel in order to fit around the starter or other accessories. Not so in my case. The Van's snorkel fits around the SkyTec starter I have installed perfectly. I did not require any fiberglass work at all on the snorkel with my installation. The one area I did have to modify was the bottom of the cowl where the #2 exhaust came down from the cylinder. It was close enough to the bottom of the cowl that it was getting the fiberglass too hot. I had to fiberglass in a small bump and lay some heat tape on the interior portion of that bump to allow for adequate air flow around that exhaust pipe. That was about the extent of my alterations though.
Ok, so everyone has their own ideas about how things should be built. I am sure there are those who will post accordingly in answering your questions. All the time I was building I spent an awful lot of time perusing through this forum for anyone who had experience with this type of setup. I was just like you back then. Wanting details and any information I could find. Most were telling me: "Don't do it." "It is too much work." "Just get the airplane flying." This was advice coming from a lot of experienced builders who, even to this day, I still hold a lot of respect for. However, I was building something different so I was just going to have to take their advice, glean what I could from it and move forward. That is where you are now. I had a lot of push back by all types of individuals, vendors, manufacturers, forum posters when I chose to install my ECi IO-340 stroker with the forward facing cold air induction and ECi fuel injection system in my 9A (
Just as a note, I am not in any way affiliated with ECi other than as a satisfied customer). If you are are interested in the cold air induction, look into the ECi setup. Talk to them, they have a lot of good advice on installing them (
If you are going to OSHKOSH, they will have a booth there).
So as far as the cold air induction, I will tell you if this is what you want, this setup can work. It DOES work and it works very well! It is really not any more complicated to install than any other part of the project. It may take a little head scratching but you will eventually be able to do it. Once you do you will find what a great setup this is. Good Luck and keep after it. Let me know if I can help.
