cjensen
I installed the forward elevator push tube tonight, and it operates smoothly. However, with the tube at it's lowest point (approx. neutral stick), if you press down on the tube, it hits the pass thru at the 705 bulkhead. It's not resting on the pass thru, but it only clears it by a sixteenth or so.
Is this normal, or are people putting some type of felt or equivalent to prevent a metal to metal rub? I don't know that I can file anything because the bottom of the pass thru is right at the top of the rear spar bar.
Again, it DOES NOT touch the pass thru without pushing on it, only when it's pressed down slightly.
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![11-9-07-007w.jpg](/proxy.php?image=http%3A%2F%2Fwww.chadandbrittne.com%2Fimages%2FFuselage%2FCenter%2520Section%25203%2F11-9-07-007w.jpg&hash=6a1a49696d5b7f3d145fa0b4e3303c87)
