I'm not sure what good replacing the canopy decks would do. I don't think they're the problem. Perhaps the longerons were bent just a tad off there so you're just a bit wide. I THINK there's a bracket made out of angle that sits on the vertical part of the deck. If that's flush up against the backside of the instrument panel, isn't that going to "cover" the gap from the backside?
The only problem will be that given the gap, it might be tough to get the hole for the screw/bolt not to exceed the edge distance on the bracket, but you can always use a bigger piece of angle there.
I don't see the big deal here although I admit, thoughts of a Lindy never enter my mind.
