dan carley
i would like to know which app do most people
foreflight or Garmins pilot not sure which one is better.
thanks
dan carley
thanks
dan carley
thanks
dan carley
The ADSB In solution you pick will dictate which moving map solution you use on your iPad or Android.
No dog in this fight at all, but I have to say ForeFlight does what you are describing also. In both apps you can see IFR routes, victor airways, TFR's, etc. In the beginning of all of this ADS-B stuff there were quite a few differences. Now these two apps are very similar.I guess ForeFlight is fine, but here's why I use Garmin Pilot instead. ForeFlight presents you a "sectional". A year ago, I planned a trip from Atlanta up to Milwaukee. I used AOPA's flight planner which also uses a "sectional" like ForeFlight. Then I double checked the route on Garmin Pilot. I discovered I had planned myself thru 5 class D airports. Never saw the darned things,---reason, sectionals are just so "busy". Also trying to find intersections and/or waypoints on a sectional presentation is next to impossible. (These come in real handy while hugging the shoreline of Lake Michigan right on the edge of or just below Chicago O'Hare's class B.) On Garmin Pilot, this is a snap. Very easy to see.
I don't know the proper name for Garmin Pilot's format, but its just like AOPA's flight planner "used" to be maybe 5 years ago, before they changed to the sectional map format.
You can try Garmin Pilot for free for 30 days. I assume ForeFlight has a similar offer. Have fun
