For those just starting finish kit
JBPILOT
I might advise skipping the wiring section for a while. Jim Cone and I have run into a bunch of problems with wiring. My main harness does not have some of the wire pins installed. ( very small crimped ends ).
Also, the trim wires installed in the tailcone do not have pins installed either on the front end ( and they are supposed to per the instructions ).
As Jim has stated the AP wiring harness going toward the rear is too short ( YES I KNOW NOW ) ! !
I also think I am missing one wire that was supposed to go to the rear tailcone - not sure yet - waiting for answer.
Many small wire ends and misc. are missing. You have to skip thru a lot as you go. Might be better to wait a while. I'm moving on.
John Bender
JB
If you are looking for a wht/yel wire for magnetometer Dsub, check the revised plan. That wire has been eliminated.
Sure is nice having you guys de-bug the finish kit while I'm soaking up some Mexican booze and sun shine.
Now get back to work!
"Feeling Hot Hot Hot."
mrt890
You are soooo correct. I actually had the revision page right beside the page I was working on. I usually staple them together.
I can put some more of the wiring together now.
THANKS ! ! ! !
John Bender
