Foam Tubing Supports for Brake and Fuel lines
I'm thinking about fabricating some nylon isolators to support my brake and fuel lines in the center tunnel of my 7a. The foam isolater shown on the plans looks a little hoakie.... What have some of you builders done in this area. Has the foam isolator worked out for you? Anybody have some photos of how they did this? :)
super soundproofing bought at Spruce.. I went wiht 1/4" thick.. see a thread from just a few weeks ago on this topic (also under 7/7A sub-forum)
fuel line support
Here's what I did. Tunnel cover has two strips of 1/4" foam to provide some isolation as well. There are grooves cut in the foam to allow the fuel lines and wires to nest.
Vern Little
RV-9A. Done, waiting for final inspection!
