3M 5200
I too was wondering about an alternative to Proseal for the foam ribs. Also wondered if I could adhere to a completely primed surface without the masking and scuffing. So here was my test:
I prepped a scrap of aluminum and primed as my usual method: scotch-brite, Prekote, AKZO primer sprayed lightly. Allowed 24 hrs. For cure.
Applied 3M 5200 (fast set) to a couple of scraps of rib foam, and to a couple of aluminum disks. Allowed to cure 24 hours.
I cannot budge the items off the aluminum, there is a slight flexibility. I would damage the foam before the adhesive failed. No difference between primed or unprimed surface.
My very unscientific conclusion is that 3M 5200 has an excellent bond to bare aluminum, foam rib material and AKZO primed aluminum. Advantages are that it is cheap, available at Home Depot/Lowes, one part, and I find it easy to apply. Also storing mine capped, sealed and zip-locked. Will see how long it lasts before starting to cure in the tube.
I will try it on the elevator/trim tab ribs and trailing edge, over primer. Seems very robust to me. If anyone has had a dissimilar experience I would be interested.
