I had to take the time to recommend and commend Paul at FlyLEDs. I have ?the works? lighting kit on my 9A and the lights are super bright.
For the last couple of months I had been chasing gremlins in the lights. On preflight it seemed like I would have a different light out each time. It finally centered on my tail light/strobe and was not working. I reached out to Paul for any suggestions on sorting out the problem. Paul went above and beyond the call of duty by exchanging quick email responses with helpful tests I could run to slowly rule out different parts of the system as faulty.
In the end it was some faulty ring terminals with oxidization on them on a block under my seats. (My hangarmate assures me that its always something simple). I could have spent lots of money or time on new lights or new control boards - but Paul?s help allowed me to chase the problem down to replacing four ring terminals.
Way to go Paul and thank you. You guys should check out flyLEDs for your plane. Good system layout and design makes it an easier addition to your plane and those lights are so bright its crazy! If I?m coming to your airstrip - you will definitely see me coming!
Wigwag at ya later
Tim
Wigwag at ya later
Tim
