Be aware that the tail light mounting bracket (bottom of this flyled page https://flyleds.com/products/#!/Tail-Light-kit-model/p/48165109/category=0 ) four rivets that connect it to the fairing can crack the fairing. The bracket is very useful but riveting is apparently not going to work.
I installed it today and it cracked the fiberglass fairing at three of the 4 holes. I sanded off the gelcoat to confirm if it was just gelcoat and it is the fiberglass also - cracked all the way through. Sigh. Have to figure out an alternative to mount the bracket. Maybe proseal or Click Bond adhesive it on. The bracket is underneath the led light and is a newish accessory to make it easier to mount the tail light onto the fairing.
