JonJay
A gracious neighbor allowed me to use his 3 since I had never had the chance to fly one before. Pretty much flies like an RV.
I am only 5'10" but I have relatively long legs. I don't know how tall people like R.V. can even get in. Once in it was very comfortable and surprisingly roomy.
Taxiing the non-steerable tailwheel took a bit of play with throttle, rudder, and a bit of differential braking but I adjusted quickly and it handled well on the ground.
As you can imagine 150hp in a less than 800lb airplane flat gets off the ground. Climb out was very RV like and with the electric pitch prop set flat, it soars to the sky quickly at full power. Adjusted to cruise to 24/24, this particular 3 is still quite a bit slower than other RV's. Not sure why.
Control pressures feel about the same as my 6, slightly more sensitive in roll and perhaps a bit more than that in pitch, but not as much as I expected.
Stall's, again RV like. Things get mushy, a little shudder, and finally, if you work at it, a nice clean break. Virtually no loss of altitude in recovery. Slow flight was as predicted.
I was surprised with the lack of float on landing being such a light airplane. Landing attitude was intuitive and visibility out the side corner and the short gear made it very easy to know where the runway was. It pretty much stuck on landing and stayed there. It rolled out nicely and very short. I think the light weight has an advantage over other RV's. I could easily land the 3 in under 500ft in calm conditions.
While I am impressed with the 3, it flies and handles like my 6 when I am light, kind of what you expect from an RV. It is slightly less stable but still feels solid. The controls are slightly more sensitive.
With all of the hype about the 3 that has propogated this forum, perhaps I was expecting some mind altering event. It was a lot of fun but I won't be trading my 6 anytime soon.
I still had the RV grin when I parked the airplane as my neighbor joked; "You only have half of an RV grin. It's a 3, half of a 6".
Thanks to my neighbor for trusting me with his airplane and I enjoyed the experience. How could you not? It's an RV.
