Lan Vinh Do
Hi
I found a big leak in my right fuel tank. When i bought the plane, the builder said that he had a fuel leak on the right fuel tank. He slosk the tank and didn't had any problem after.
during the last two flight i began to smell fuel in the cabin. I remove all the inspection panel in the cockpit and didn't found anything.
Today i've put some air in the tire and found a lot of fuel under the fairing of the right wing I remove everything and found that it was probably a leak from the jonction of the inner rib and the skin of the fuel tank in the upper most part of the fuel tank. Probably didn't notice it before but las time i fill the tank it was cold outside and with the warmer day, it pressurize the tank a little bit and it leak. This area had more sealant so it was probably the place where it leak before.
I had a couple of rivet that was leaking and 2 week ago i already email evan aviation to order 2 new fuel tank before i found this bigger leak.
My question was : during the time that i am waiting for the new tank, is there any problem to fly with a almost empty fuel tank on the right and a full tank on the left other than the roll tendency ( i have to renew my IFR and want to do some training) I can probably leave 10 gallon an it will not leak)
https://picasaweb.google.com/lh/photo/pYNHurqzck_GH-iurQPo4C7wapnxqtjAlUDZ7yz7_BA?feat=directlink
thank you
Lan Vinh Do
thank you
Lan Vinh Do
