BrettShaffer
Member
I imagine this is fairly simple stuff that somehow I'm not understanding / wasn't specifically taught in my synergy intro course
Refer to link below:
https://photos.app.goo.gl/mPTwiZmbJtEBEdJS8
Two questions:
1: I'm confused about which way to flute these with fluting pliers to get the bend out of them? Youtube videos I've seen usually have the sheets with a bend in the middle and you flute until the corner pops up slightly, but these seem to have the corner already popped up and not sure if I should be fluting one side or the other and what direction to hold the fluting pliers.
2. Step 2 in the photo has two bends. A) How precise to 9 degrees does this need to be? Is holding it next to a protractor and eyeballing it sufficient? The forward bend seems simple as there is already an angle to push against. It looks like for the aft 9 degrees you need to create a bend line at the specified point with a hand seamer. Do I hold the flat end of the hand seamer against the dashed line and push to create the bend?
This is the tool I'm imagining using.
https://www.cleavelandtool.com/products/offset-hand-seamer
Two questions:
