TheBoatLife
Member
I'm doing the rivets on the vertical stabilizer, the first real batch of riveting on this project, and I'm a little unsure of what to do or if I need to worry.
Most all the flush rivets are great, nice and flush, but there are a few that aren't perfectly flush. I know drilling out and removing rivets is potential to cause more problems, so I started with the worst of the 3.
I drilled it out just fine, but dropping a new rivet in I realized the rivet doesn't sit flush so it wasn't bad method with the gun, I'm assuming maybe I didn't dimple it correctly?
Is that anything to worry about?
