Cherry seems to have a bunch of flush #4 blind rivets in varying lengths:
http://www.cherryaerospace.com/html/product/blindrivets.html
I started looking through this pdf http://www.cherryaerospace.com/files/pdf/catalog/CA-1005.pdf and it looks like there is a number of possible options.
Considering that most Cherry grade rivets sell for in the neighborhood of .20 cents each (at teh bottom end, many of them are much more), I think most builders would decide that an extra $2000 just to make the airplane flush riveted is probably not worth it.
If you change to flush rivets does this take the plane out of LSA?
And I like the jab 2200 (I am not saying the jab is an improvement) Less is More: Embracing Simplicity
It should not remove the airplane from light-sport parameters. At these speeds, flush rivets should not noticeably affect the speeds. Mostly the reasons for using flush rivets are ease of painting, cleaning and cosmetics.
Mel,
Are you saying E-LSA is possible with flush rivets?
Mel,
If you've got to use a Jabiru, you might want to consider the 3300 instead of the 2200.
The stock RV-12 has unexceptional climb and take-off performance, and if you install the Jabiru 2200, you'll reduce the power by 20% and decrease the prop's thrust by reducing its diameter - the Jabiru engines turn the prop faster than the Rotax.
Both of these will hurt the take-off and climb performance.
Flush rivets would disqualify the aircraft from E-LSA.
The 3300 would remove the plane from LSA
If I was to consider the 3300, I would build the RV9.
The LSA is favorable as I am in good health, 66 years old and don?t want to worry about a medical.
This will be a True Light Sport Aircraft
This will be the plane I want
Why would the 3300 make it not LSA compliant? As long as it doesn't exceed 138 mph, it'll be LSA compliant.
