mosquito
I have a UMA 7-100-20 Manifold Pressure gauge in my -6, installed circa 1996. Getting ready to start up last night, my co-pilot noticed the gauge appeared to be about a quarter filled with what looked like oil. Rut roh.
I pulled the cowl and nothing seems amiss. The manifold pressure line comes off a primer port to a T fitting, with one line going through the firewall to the gauge and the other line going to the MAP port on a P-Mag, mounted on the right. All of the lines seem clear of fluid.
I've pulled the gauge, and the fluid will drain out of the instrument through the vacuum port. It doesn't really smell or feel like oil. I'm not sure what it smells like. I've put it under the nose of anyone who will smell it; an A&P friend said it's not oil, he thinks it smells like glycerin (?).
Perhaps the instrument has a fluid damping mechanism that's sprung a leak? Other than that... could oil be getting into the P-Mag?
This one has vexed all of the airport pros and bums I've run it past. Anyone have any ideas?
-jon
![uma-mani-gauge.jpg](/proxy.php?image=http%3A%2F%2Finsanitize.com%2Fvaf%2Fuma-mani-gauge.jpg&hash=dac22e8c70470a532d4627fd1165fe94)
-jon
