and another thing. I just looked at your website.
Prop governor: Mount the cable bracket and cable, and then adjust the arm for proper position before you mount the engine.
To adjust the arm, cut the lock wire, loosen the screws, DO NOT REMOVE THEM, and rotate the assymbly as required. tighten and re-lockwire.
If you wait till the engine is hung, you will have to remove the governor to make the adjustments (yup, I did this).
