rv9aviator
I am having a small problem installing the floats in my Rv-9A tanks. The float has a groove around one end that snaps into bent float wire . After I bent the wires and installed the floats into the tanks I noticed the float was hitting the tank stiffener on the right tank when in the empty position. The one on the left is very close to hitting also. I've gone over the drawing on bending the float wire several times and am sure I did it right. The fix is simple enough. All you have to do is snap the float out of the wire and turn it the other way. This makes the end of the float closer to the rear baffle plate instead of towards the leading edge. The only drawback might be the fuel is sloshing between the tank ribs through the hole in the bottom of the rib that is now in-line with the float. Has anyone else had a similar problem? ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
