WingedFrog
Trying to install the baggage trim from Flighline. Unable to put in place the part called B1 which is the panel that fits the upper part of the bulkhead (it has "Experimental" woven in the fabric). My feeling is that it can only be installed if the gas tank is not in. I did not try to bend the panel too hard to push it in but as it comes with a set of hardware including nutplates to fasten it to the wall, I'm afraid that I will have to wait until I remove the gas tank for the yearly inspection to install it. If anyone managed to install B1 with the tank in, I will be glad to hear from you.
