jsharkey
Suitably inspired by the following post I ran some tests today and input the data into the NTPS spreadsheet.
http://www.vansairforce.com/community/showthread.php?t=50164
TAS as indicated by my temperature and pressure corrected Dynon D100 is consistently reading 5 or 6 kts higher than that calculated from the GPS496 ground speeds.
Anyone know what this means? It implies that the pressure difference between the pitot and static ports is higher than it should be. It's unlikely that the pitot is high so could the static read low if it has a leak?
Jim Sharkey
RV6 - Phase 1
PS - std dev was more like 1 kt instead of the 0.1 kt shown in the post above. Guess I need to fly more accurately![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
PPS - I entered magnetic heading and not GPS ground track - need to do more flying![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Jim Sharkey
RV6 - Phase 1
