Flight following protocol
erich weaver
Patron
Dumbass question, but I’m asking anyway. What is the proper way to request VFR flight following when your planned route is not direct and has a few dog legs in it? Do you just say your final destination and then “via x and y” ? I have always just gone direct previously.
Thanks.
I typically state my destination and provide a couple of key "via" waypoints if not direct. BTW, always be sure to cancel your FF with ATC and receive ATC's acknowledgment of your FF cancelation -- otherwise ATC may initiate "lost aircraft" procedures to determine the fate of your flight.
X Center NXX request…
NXX Go with your request…
NXX is X miles SW of airport X at 3,500ft requesting VFR flight following to KXXX via Point XYZ at 3,500ft we are a Experimental RV-8A.
They will issue you squawk, you ident they pass you altimeter and tell you maintain VFR, altitude your discretion.
OR
You tell them the airport you are flying to and say you will fly N/S/E/W for so many miles prior to your destination. Trucker comm works too.
OR
Just so you know, some controllers hate the word "request". It's not in their handbook, and of course you have a request, why else would you be calling them? Just tell them who you are (N48HT, RV10 slash uniform), where you are (5 miles southwest of Tracy, VFR at 3 thousand 5 hundred), and what you want (request flight following to Red Bluff). If you have the local altimeter setting throw that in (we have information Victor at Stockton). Do not ident unless asked to do so. I generally advise them of altitude changes but not small course changes unless they request them.
Very true, but if I just start rattling off this entire sentence they will just ask me to repeat it again. I can only be as efficient as the guy on the other end. That initial call is just to get their attention. I know it’s probably not in the JO 7110 phraseology.
Sorry I forgot to add you ident when they ask you to ident which is almost always in my area with military controllers.
I hear you. If you want attention, just say your call sign and "over". In my local area we have at least one sensitive controller, and when someone calls up with "request" everyone on frequency is subject to a 30 second tongue lashing about radio usage. Others don't seem to care so much, or are too busy to say so.
I do this everywhere I go. I don't have to repeat my intentions, and its the way I was taught as a student pilot.
Opposing Bases is a great podcast. Entertaining to listen to, and gives tons of controller insight on questions like this.
There have been enough examples given of ways to skin this cat. Most controllers will just be happy that you have volunteered to be in the system and they can talk to you. Use your judgement with respect to how busy the radio is and what you include in the initial call. Stating the information in the order they enter it is typically more helpful than anything else you can do, but unfortunately that is not consistent across all facilities and systems. There isn't really a 'perfect way'.
As a enroute controller, I'd rather you call up and say your callsign and request or callsign and wait for me to acknowledge. As soon as I acknowledge, "N1234 is XX miles west of JFK at 7,500, We are a RV-10. requesting flight following to LNS." I only need a callsign, type, and destination for basic flight following. If you are near a class B or C, some people will ask how you are going to navigate to find out if we need to coordinate or hand you off through that approach. Just my viewpoint as an enroute controller.
"Xxx center, n761gs with VFR request". Has always worked for me. Usually I get it on the ground in our Class D with ground controller. Win, win
center. N1234, VFR request.
center will respond with probably “N1234 say request”
Then give them the 3W’s No more, no less. (Who are you - N1234 Vans RV6, Where are you - 10 miles south XYZ 9500, What you want - Request VFR flight following to Airport Identifier) No sense in clogging up the airwaves with unnecessary information.
Keep radio chatter simple, short and direct. All you care about is the squawk code. Let them worry about the behind the senses work. If they want/need more information, they will ask when time presents itself.
