flyenforfun
I wanted to post this question on here as a second opinion.
I am having a problem with my flight controls now that I have the ailerons done and the aileron stops in. My first problem is with the rod end on the forward end of the pushrod that goes from the aft stick to the bellcrank (I know, confusing). When I move the sticks to full left and right aileron deflection, this rod end (the one that rocks left and right) contacts the sides of the stick weldment. I will attach a picture to help. It doesnt seem to hinder the movement of the controls, but I think I feel a drag on them when I move the stick forward and back with full aileron deflection in. This rod end just has the small spacers on each side, part number 5702-75-060, per the plans. It seems when the bolt is tightened down, the stick weldment squeezes together slightly. Has anyone else noticed this? Can I add more spacers? The picture below is of the rod end in question with the stick pushed to full aileron deflection.
My second problem is at the aft end of this same rod. With the stick at full down (forward), the bottom of the bell crank is pushed all the way back as it should. At this position, the Y of the bell crank contacts the top sides of the rod end. This also doesnt seem like a good situation. Is there anything that can be done here? My thought was to shorten both of the elevator pushrods to make the angle of the bellcrank at full down elevator not so extreme. Here is a picture at full down, its hard to see but the bellcrank is touching the rod end here.
Any help is appreciated, I want to solve this issue tonight and move on. Thanks everyone.
![ct1.jpg](/proxy.php?image=http%3A%2F%2Fi759.photobucket.com%2Falbums%2Fxx240%2Fhotcarl_01%2Fct1.jpg&hash=434b4dde9601bd41c9cc2bf334d8be9f)
![ct2.jpg](/proxy.php?image=http%3A%2F%2Fi759.photobucket.com%2Falbums%2Fxx240%2Fhotcarl_01%2Fct2.jpg&hash=2866522aaaae52883da82fd9a3a1d275)
