I'm planning to use stainless braided teflon brake lines from the gear leg bottom to the calipers with aluminum tubing from there up to the firewall.
How long does the hose need to be from the caliper to the gear allowing for a service loop and not interfere with the wheel pants?
Is using aluminum tubing down the leg and then transitioning to stainless braided teflon hose a good idea or do I just run stainless braided teflon hoses all the way from the caliper to the firewall bulkhead fitting?
