I plan on ordering two teflon ,ss braided brake lines for the gear leg runs. If aluminum lines are to be used the manual says to wrap or twist all the way arround the bottom of the gear leg tubing as shown on page 46-07, figure 4. I see this is a flex for the line, as the brake assembly twist arrount the axels.
With a stainless steel line I see no need for this full rotation, just a generous amount of line should allow for this rotation/oscillation?
What have others with SS brake lines done?
Thanks Ron
Thanks Ron
