Has anybody found that after mating the wings to the fuse and drilling the rear spar, that you then had to put a joggle in the inboard end of the flap so that it could mate with the fuse? I am sure I set the fuse level and the wings at the correct incidence using the method shown on drawing 38. then when I
refitted the flaps to the wing I found they would not go all the way up because they fouled the bottom of the fuse, hence having to put the joggle in the flap. Having once drilled the rear spar is there any known fix for this problem, or any known reason why this would occur?
Thanks for any help
Phil from Oz CN 72295
Thanks for any help
