J Twilbeck
I am working on Section 40 Flap System. I installed the torque tubes and UHMW Bushings and found a lot of friction and/or resistance in the system. You can push the center flap crank with one finger back and forth, but it does not rotate easily.
My question is, did others experience friction/resistance in the system? Should it rotate without any resistance?
