he reflex position (-3 degrees) is the "standard cruise position". Van's limits the max speed on the 0 degree trail position to 122 Kts. As stated above, in the trail position at 0 degrees, the load is transferred from the rear wing spar to the flap actuator mechanism. At 15 degrees, the speed limit is 96 kts and at full flaps, 87 kts. The actuation mechanism is not designed to accept a load beyond the limits imposed by the above speeds. I would not think that you would need to fly a pattern at more than 122 kts. My pattern speed is 80 kts, and short final is 72kts with full flaps.
