I'm in the process of riveting my flaps together. I've riveted the top skin to the spar and main ribs, but that last trailing edge rivet in the main ribs is a bear. I've not found anything around in my shop that looks like it would suffice for a bucking bar in that location. I'm sure I've seen some pictures of others methods, but a quick search here didn't locate any. I've seen some planes with a pulled rivet in that spot, like the bottom skin is put on, but would really like to use a solid if possible. Any help would sure be appreciated.
