Rolly,
I ran the wires up the center and drilled a hole (installed a rubber grommet) by the aft vertical support. The wires ran straight up the inside of the vertical support (Sorry, can't remember the number), and were secured with two zip-tie pads glued to that thing.
The wires were connected via blade connectors, which was a good thing since I had to remove and clean my flap motor at 75 +/- hours.
