Nashpdman Well Known Member Friend Jan 20, 2025 #1 How do you manually extend the flap motor? I'm not familiar with the wiring circuits. Thanks! Attachments 1737417710417.png 411.6 KB · Views: 59 1737417742665.png 443.4 KB · Views: 59
rocketman1988 Been around for awhile... Sponsor Jan 20, 2025 #2 You can connect the blue and brown wires to a 9v battery. Reverse polarity reverses the motor. It will run slow with only 9volts
M Morepower Member Mar 25, 2025 #3 Trying to do the same thing, but my flap motor only has a red and black wire?
Sam Buchanan been here awhile Mar 25, 2025 #4 Morepower said: Trying to do the same thing, but my flap motor only has a red and black wire? Click to expand... Hook the wires to a battery, if the motor runs against the stop, reverse the wires to make it run the other direction.
G gkochers Well Known Member Friend Mar 25, 2025 #5 colors may vary, it’s always the two fat wires. The skinnier wires are for the position sensor.
Nashpdman Well Known Member Friend Mar 25, 2025 #6 Mine would not run on a 9 volt battery, had to use a regular 12 volt car battery.
