Planned for 7.5a
While 5a seems to work for most, I also simulated, and would get 3.5-3.8a running loaded (depending on temp) but would occasionally see 4.5a on startup loaded (one down position to next downward position). I went 7.5a and wired accordingly. I'm using the direct acting switch supplied with the kit.
Other threads noted have discussions re: issues at 5a long-term.
Remember, a CB is a shunt(thermally triggered), a shunt is essentially a resistor in series with your circuit. If you can size up, voltage drop across the CB at the same amperage is nominally less. If it matters, I dunno, but good practice and all of that.
Rick 90432
