Vans says to center the flap motor actuator arm when installing the bracket for the rod end bearing, which I have done. I am thinking it is best the have the flap motor as high as practical to allow for full travel when lowering the flaps. The problem I have is the actuator rod starts to contact the front of the hole about a quarter way down when lowering.
Is it common to have to enlarge the hole the actuator rod passes through? This seems easy enough, but as I think this will be quite visible I need assurance before I start cutting!
