flydjd
Hi all and seasons greetings.
I have searched this subject and see that some builders have had to bend the lower flap skin up or joggle it down according to their rigging requirements.
In my case the skins are being bent down by the fuselage, left side more than right. In fact the leading edges are rubbing against the fuselage bottom skin. (All wing incidence settings double checked OK since drilling rear spar attach.)
I know that others have joggled the flap skins using hand seamers and I think that this will be the answer for me as I don't want to just cut this skin off completely and leave the flap rod hole uncovered.
My Q is this (eventually) :-
Has anyone trimmed these skins with an S shaped cut to clear the interference but maintain the cover of the flap rod hole.
If so what are the aerodynamic considerations ?
QB Wings and fuselage.
