Still a work in progress.
GAHco,
I like it, simple is good!
If this airplane is flying, have you had any issues with the nuts coming loose?
And if the answer is no, do you recall what size the nut is?
Its not flying yet. I expect no issue with loosening.
I have all the airframe done, except the fuselage (slow build)
The nut was anMS21043-04, you could just as easily use MS21042L04, or MS21042-04.
TIP,
leave the pin long enough to allow about 1/4" extra including the hinge , the nuts and a couple threads after the nuts. This allows you to hold the pin from rotation ( needle nose vise grips) while taking the nut of with a very tiny wrench.
You can use Vans supplied hinge, but I did not, I used the same thing in the structural version. MS20001P3-2700,
http://www.gen-aircraft-hardware.com/IMAGES/PDF/MS20001.PDF
I had to cut it to the correct length. I did this with the pin out. This left the pin way too long, it is after I fit the flap on and put the longer pin in. I then measured and cut the pin to the required functional length, and used a good quality 4-40 die to cut the threads.
If the Vans Pin is not long enough, the 6ft replacement # is MS20253P2-7200
http://www.gen-aircraft-hardware.com/IMAGES/PDF/MS20253.PDF
Remember the old addage when cutting to length an be careful.
"I cut the darn thing three times, and its still to short"
Whatever way you ultimately choose best wishes and Have Fun!
