I have the flap handle assembly done and attempted to install it. The fit is tight but I can get it in between the seat ribs by canting one of the F1262 blocks through a lightening hole, but then I can't 'slide' it aft to bolt in the blocks because the flanges of the lightening holes project or point into the tunnel.
I am tempted to either cut 1/8 inch off each end of the cross mounting tube, or to flex the seat ribs and use some gentle brute force to tap the assembly aft toward the nutplates that the assembly bolts into.
Did you have difficulty here, and if so, how did you overcome it?
thanks for any hints
JohnF
JohnF
