alpinelakespilot2000
Has anyone had any issues with the holes their flap brackets (W-925, I think) on the wing not lining up with each other or not being parallel to the wing itself?
Originally when I built the wings, I ran the string through all three flap brackets as directed in the manual. They were then, and still are, perfectly in line with each other. However, what I've found on mine is that the holes in the brackets are not the same distance from the wing itself. The hole in the middle bracket is 1/32 farther from the top wing skin than the hole in the inboard bracket and the hole in the outboard bracket is 1/32 farther away still. The net result is that the trailing edge of the flap is about 1/16" closer to the wing at the inboard position than it is at the outboard. I have no idea how this could be, since most of those holes in the flap brackets were punched by the factory as were the holes in the ribs to which they attach.
I don't know whether this 1/16" matters, and the flap does seem to swing through it's full motion very smoothly, but it seems really strange that the holes in the brackets would not be lined up with the wing. Also, it prevents the flap from aligning with the aileron as well as it might otherwise. This is actually more cosmetically apparent because it allows the outboard corner of the flap to hang down about 3/16" lower than the aileron when the aileron is at its neutral position. (This is especially frustrating after all the effort I went to to get perfectly straight trailing edges on the flaps and ailerons.)
Anybody else been bothered by the same issue? Thanks.
