Couple of questions as I get back into the floor of the QB fuse:
1. I laid out and drilled the holes through the F-445 flap blocks, everything looked great and in position, but I am just barely off on the edge distance for the right side hole through F-815C:
Thoughts? Anyone had a similar problem? Gonna email Vans on this one.
2. The QB fuse floors are not level. There is about 3/16" difference between the F-815C and the other subfloor structures (sorry the image is rotated):
This leads to bending of the F-830PP floor when installed and the flap blocks are tightened. Not sure if I should make spacers, or ... ? Anyone experienced this?
Thanks in advance.
Thanks in advance.
