JamesAllanL
I'm New Here
Hi everyone,
This is my first post, probably with many to follow. I can't find any reference to this.
I'm installing the flap and aileron braces on my quick build wing. The wing already has flush rivets installed from the factory where the ribs attach to the rear spar, where the braces are to be mounted. I'm assuming these rivets do not need to be drilled out. This would result in the braces not having rivets placed where the brace holes match with the rib location. Hope this makes sense. Is this correct?
Thanks in advance.
Allan James
RV-7A Quick Build
Huntington Woods, MI
Thanks in advance.
Allan James
RV-7A Quick Build
