I just installed my flaps while the wings are sitting in the cradle. Bottom skins are riveted and everything seems straight, except the flap for the right wing will not nest completely in the recess. It appears to be striking the back of rear spar just outboard of where the skins begin. This causes a differential between the flap trailing edge and the aileron of approx 3/32". The flap seems straight, the wing seems straight. Left wingflap and aileron align perfectly. Would this work itself out when the wings are hung on the fuse? There doesn't appear to be any adjustability since the leading edge of the flap is striking the rear spar.
