Charles in SC
I have a question about a safety wire hole that is to be drilled in the aurora bearing end of E S 85615-157.
What is the best way to drill this? I am guessing this is hardened steel and you have to drill it at an angle. Can I start the drill straight then turn it after it starts or should I drill 2 90 degree holes, one from the end and one from the side so they meet? Or am I just making this harder than it should be. I am famous for that.
Thanks in advance for any advice as always. This forum is a great source of information!
