flame master
rwarre
I started with Vans flame master on my 1st tank but used more so didn't think I would have enough for the second tank. i order from Boeing and thought I was getting the same stuff. CS3204 B-2. When I started mixing, the part A base is not the same consistency as Vans. It is slightly more runny. Color and mix is the same. Actually easier to apply. The label says CS 3204 A 1-2. Is the difference a problem?
Type A is a honey-like consistency.
Type B is the thick paste we all love.
The 1/2 or 2 is the working time in hours.
In general, Type B is used in between parts, and Type A is used to overcoat rivet heads and edges. If you do both it adds to the seal quality. I used a craft syringe to do that.
Tank Sealing 1.jpg Also see View attachment 43739
You can also get another sort of tank sealant called "Access Hatch Sealant." It's designed to let you remove a hatch.
Dave
