pitts12driver
Member
Much to my chagrin, a guest accidentally knocked my left wing of my RV7-A off of the sawhorses while we had it resting. The leading edge was dented along the second rib in from the root, and the rib has a small buckle. Clearly I need to do something, but I'm trying to understand my options.
1) Remove the skin from the tank, replace the 2nd rib, reskin. If this was a normal flying surface that would be my approach. However the tank sealant complicates that approach and I worry that it would be really difficult to get all the mating surface clean enough to reseal.
2) Build a new left tank. It's actually not that much work, but I worry that the project I took over is from 2009, and I have no idea if the current model pre-punched holes would remotely match all the nutplates already installed on the wing.
So, I'm not really sure how best to proceed. All constructive thoughts welcome
