txnbuilder
Active Member
Today, while riveting one of the wing leading edges, I managed to drop my nice heavy bucking bar inside. The result was a ding/crack in the skin! ![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The picture shows the crack, but doesn't really show the ding very well.
I have already sent a message to Vans, but I would appreciate any suggestions on how to address this.
The crack is just the right size so I can drill it out with a #30 drill. So, I think I can try to first flatten the ding with a thick spoon, and then drill the crack out. Then dimple and plug the hole with a blind rivet. Why not a solid rivet? Because the ding is right on the tip of the leading edge, with no rib to back it up. I am afraid of making things worse if I hit it with the rivet gun and slip just a little....I'm thinking some light sanding and filler prior to final paint should make the blind rivet dissapear? -- thoughts?
Thanks!
Luis Orozco
Austin, TX
RV-7A Slowbuild Wings!
![134leadingedgedent1bs6.jpg](/proxy.php?image=http%3A%2F%2Fimg227.imageshack.us%2Fimg227%2F1412%2F134leadingedgedent1bs6.jpg&hash=e7b6be34aed87ff767ca138289f46111)
Thanks!
Luis Orozco
Austin, TX
