I'm finishing up my wings, but don't want to rivet the bottom skin on for a while. Should I wait to fit the wingtips until after the bottom skins are riveted, or can I cleco the skins in place and start to match drill the tips?
Lynn
Do not fit the wing tips until after the wings are on the plane, the flaps are exactly right and the ailerons are rigged perfectly (remember to clamp the elevators in neutral before rigging the ailerons).
After all this is done, then and only then do you fit the wing tips. The trailing edge of the wing tips can be moved up/down half an inch. Treat the wing tips as you would control surface rigging.
Carl
The tips are installed to match the ailerons, which are rigged to match the reflexed flaps. All of that can be done with the wings in a cradle or sitting on sawhorses. There is no need to bring the other factors into play when are attaching the tips.
