Aero_Octaveus
I've cleco'd the tanks up and I'm starting to fit them to the wings/z-brackets. I see that most builders use ratchet straps to fit them to the wing to hold them in place while they drill the W-423 joint plate and the baffle/z-brackets. (I get a great alignment on the bottom skin, but I'm having a tough time getting the gap closed between the tank skin and the top wing skin with this method.
I'm toying with the idea of drilling the tank/spar attachment holes to #19, dimpling and using some #8 screws to help attach the tanks to help with a proper fit. ( I see Andrew's RV build site did this http://n999za.com/2011/02/26/right-tank-work/
If you did it again....would you use this method or just keep with the straps?
