I'm suffering through the trials and tribulations of shaping the canopy frame. It's close, but there are a couple of issues I could use some advise on.
In the plans, page 9-10, it states that the canopy frame expansion will be compensated for during the "latter stages of canopy fitting". In addition, there is a caution that emphatically states: do not try to bend or reshape the frame after the plexi is drilled to the frame! The frame will break. On the very next page under fitting the frame to the canopy, the instructions have you drill the holes through the plexi into the frame and then disassemble and adjust the frame to make the final shape. Repeat as necessary to achieve perfect fit.
Am I missing something, or do the two instructions contradict one another?
Can you safely adjust the canopy frame bows a little after you have drilled the plexi to the frame?
One other question. How critical is it that the canopy frame side bows vary by no more than 1/8" from front to back? I have beat, bent cursed and done everything I can think of, but every time I get the rear bows to fit properly, the left side bow sits about 1/4" lower at the rear than the front. Unless there is a crital reason not to, I plan to go with it that way.
Mike
Mike
