So I tried to follow Van?s instructions on fitting the fuel tanks and ran into some issues with alignment on the Z brackets. I guess I need to figure out how to drill an ?exact? hole
Now I am trying a different method.
I manufactured a small plate with the same hole locations as the outboard aft corner of the fuel tank skin by back drilling the fuel tank skin. I bolted the Z brackets to the spar, clecoed the plate to the baffle and screwed the plate to the spar. You can see this in the picture. Things seem to align pretty well.
I will now use the baffle to back drill the 1/8? holes into the brackets. I hope this works better than relying on my measuring and drilling skills![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![u4l6p.jpg](/proxy.php?image=http%3A%2F%2Fi42.tinypic.com%2Fu4l6p.jpg&hash=327f504b3bc64abf72ca5fea32b23ebb)
