So I've finished up my left tank and everything is great, moved on to the right tank and when I go to fit it after installing the leading edge we have a problem. The method I've used is the well known Checkoway method. Everything was perfectly lined up prior to riveting and when I go to install the an4-3 bolts into the z brackets I have a slight mis alignment, maybe 1/16th. I definetly dont want to open up the holes in the spar, but my fit is perfect everywhere else. The only thing I can think of is something shifted when I riveted on the baffle. The z brackets are all labelled and in the correct locations as to where they were match drilled, and the baffle riveted on fine, minus a hand full of the flush rivets that needed a light ream to get to fit (maybe 10 total). Needless to say this has given me a headache yesterday and today. Has anyone else come across this or any suggestions? Thanks in advance.
