Hi Guys,
Looking for pictures of how people have setup the parking brake on a 7A. I am thinking about removing the standard bracket from the firewall and mounting the valve down there. This means I can use the standard hoses. I am also looking at how to rig up the park brake cable.
Also, What is the best way to run the brake lines through the gear weldments? I can see that if I follow the plans these may get in the way of the wing bolts when installing the wings. Did you run the brake lines differently or wait till the winds were fitted for the final time or is this not an issue?
Richard
Richard
